  New Posts New Posts RSS Feed - SilkScreen Thickness
h.vihvelin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote h.vihvelin Quote  Post ReplyReply Direct Link To This Post Topic: SilkScreen Thickness
    Posted: 19 Jan 2018 at 2:51pm
I can't seem to get my export to have the right Silkscreen formats.
I am setting my preferences in the Legend --> Drafting Options.
But I keep ending up with different results.
Am I stuck setting the Silk text setup on the OrCad side after export?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2018 at 3:41pm
When you update your Preferences > Drafting > Legend > Line Width, it will use that setting for every part you create.
There is no need for editing in the OrCAD PCB tool.
If you need a webcast to help you set up your Preferences, please let us know and we'll set it up for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote h.vihvelin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 6:27am
Under Drafting > Legend, I do not see a Line Width entry.
It has:
-Outline Width
-Map Outline to Body
-Clearance...etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 6:31am
Outline Width = Line Width
This page was generated in 0.766 seconds.
