  New Posts New Posts RSS Feed - Library Expert 2017.22 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.22 Released!!
    Posted: 27 Dec 2017 at 3:54pm
Version 2017.22 was just released!!
UPDATED:
  • Allegro/OrCAD PCB:
    • Fixed a problem that was preventing Pad Stack Outlines on the Assembly Layer from generating
  • CADSTAR:
    • Output to Version 18 format now supported
  • PADS:
    • Fixed an issue that was causing slotted holes to come out with a 360-degree rotation rather than 0
    • Fixed an issue that was causing parts that had a hole but no Inner Layer to crash
  • General:
    • Fixed a bug that was causing Rectangular or Square Keep-outs on the Bottom layer to be generated as Copper rather than a Keep-out
    • Parts that have multiple pins of the same name translate properly again
This page was generated in 0.449 seconds.
