  New Posts New Posts RSS Feed - Add Polarity Pads Graphic in all the Family
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artwork Master ITALY Quote  Post ReplyReply Direct Link To This Post Topic: Add Polarity Pads Graphic in all the Family
    Posted: 29 May 2012 at 7:17am
Add the possibility to have pads Rectangular on Pins 1 in the all family.
If your cad support the rounded pad or a user chose to Oblong pads.
So it will be easy see the polarity of the components even is Silkscreen is Not printed on the PCB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2012 at 9:18am
You can easily change the pad shape for all pins and have a different shape for Pin 1 to show polarity when there is no silkscreen outline.
Open "User Preferences > Components > Surface Mount > SOIC > Pin 1 Pad Shape"
This page was generated in 0.518 seconds.
