  New Posts New Posts RSS Feed - Library Expert 2017.21 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.21 Released!!
    Posted: 13 Dec 2017 at 10:28am
Version 2017.21 was just released!!
UPDATED:
  • NEW Name: changed name from "Professional" to "Enterprise", which much better suits the powerful features that have been added in the last couple years, and how the Library Expert is implemented to provide enterprise-level CAD library support to some of the largest companies in the world.
  • Preferences:
    • Fixed an issue with the Drafting Legend placement round-off
  • Allegro/OrCAD PCB
    • Fixed issue preventing Pad Stack Outlines on Assembly Layer form generating
  • CADSTAR
    • Output to version 2018 now supported
  • PADS Layout:
    • The Translator now handles unintentionally rotated pads due to Length > Height, with an offset
    • Fixed issue where slotted holes had a 360-degree rotation rather than 0
    • Fixed issue that was causing parts that had a hole but no Inner Layer to crash
  • Xpedition:
    • Fixed an issue that was causing Pad Offsets not to translate
  • General:
    • When importing paste mask via the PADS Importer, any shape that is off center of the pin is now properly filtered to associated copper, so that it becomes part of the checkerboard pattern
    • Fixed an issue where pad stacks with offsets would not be generated properly in pins that were rotated. The rotation of the pin will now be properly taken into account when generating the offset.
    • Fixed a bug that was causing Rectangular or Square Keep-outs on the Bottom Layer to be generated as Copper rather than a Keep-out
