  New Posts New Posts RSS Feed - Preferences Differences
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: Preferences Differences
    Posted: 21 Nov 2017 at 2:21pm
I think it would be nice to have a feature that spits out all of the differences between your current preferences and the default/recommended preferences that ship with Library Expert. Alternatively, the preferences dialogs could highlight or mark preferences that have been changed from the default, and indicate what the default is.
I ask, because by hand inspection, it appears that a number of the default preferences have changed since I made my own preference file. If these are bug fixes or improved best practices, I would like to pull them into my own preferences.
--John
cioma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cioma Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 3:44am
I support that, it's a must have feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 8:12am
There are a variety of XML comparision tools that will show you, with some finagling, differences between a default preferences file, and your current preferences file. It's worth a check if you created your file a while ago. In my file, there were some values that were clear bug fixes, where dimensions were changed by various multiples of 10.
Anyway, I really think this should be built into Library Expert.
--John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 8:19am
We would rather add a second row of preference options with both rows defaulting to the same values and the 2nd row is for the user to change the value to customize the settings.
This way you always know what values are the default and which values were changed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cioma Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 7:47am
Thanks Tom, I think that would be a sensible solution
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2017 at 8:47am
That sounds like a great way to do it.
John
This page was generated in 0.187 seconds.
