  New Posts New Posts RSS Feed - OrCAD/Allegro Text Block Mapping
craig4tone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Topic: OrCAD/Allegro Text Block Mapping
    Posted: 16 Nov 2017 at 12:44pm
It would be nice to have an option in the Create Footprint dialog to specify the Text Block for silk, and assembly ref designators.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 12:58pm
OrCAD PCB/Allegro is already a crowded, complicated translator, and usually spawns the most technical support. I would suggest the best way to handle this is to make a post-process script that simply adjusts the text blocks to your liking. You can also add any other tweaks so that you can filter the parts to your specific standards.
This page was generated in 0.688 seconds.
