  New Posts New Posts RSS Feed - Allegro 3D orientation
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Allegro 3D orientation
    Posted: 10 Oct 2017 at 7:38am
I am just starting to use the 3D step files with Allegro.
I have a 16 pin right angle connector footprint.
The 3D part I view in Allegro is rotated 90 degrees.
Shouldn't the step files match the footprint?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 7:42am
In the CAD tool Translator menu, at the bottom is the 3D STEP options.
Do you have the Vertical Axis set to "Z" or "Y".
Allegro uses "Z".
The 3D STEP model always aligns with the corresponding footprint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 7:48am
That fixed it. Thanks!
