  New Posts New Posts RSS Feed - Assembly Outline bottom layer is not generated
ali.slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ali.slim Quote  Post ReplyReply Direct Link To This Post Topic: Assembly Outline bottom layer is not generated
    Posted: 13 Sep 2017 at 9:58pm
While creating parts for Altium I noticed that that Assembly outline bottom layer is not being generated so as placement keep-out (Top and Bottom), the ref designator layers seems to be fine.
Anyone has the same issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 7:36am
Library Expert does not put anything on the "Bottom Assembly Layer".
Are you placing Drafting Outlines on the Bottom Assembly Layer?
Let us know so we can fix it.
Also, send us your FPX file with the part in question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ali.slim Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 11:25pm
Thanks Tom,
Sorry my bad I thought that it should automatically generate something on the bottom assembly.
Now I realized that its not needed.
