  New Posts New Posts RSS Feed - The Allegro .bat File Stops Without Loading
Kenji View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenji Quote  Post ReplyReply Direct Link To This Post Topic: The Allegro .bat File Stops Without Loading
    Posted: 08 Sep 2017 at 12:47am
When I click the bat file, I sometimes have a problem.
It is the file stops without loading to the next step.
Why?
I tried to implement the auto-run selected, but it doesn't open the next stage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 12:07pm
Make sure you have Run Scripts In Background turned off.
That option can hide a dual-boot configuration window, preventing you from being able to select the proper version of Allegro.
This page was generated in 0.171 seconds.
