  New Posts New Posts RSS Feed - Unable to connect to the running PADS application
David Baldwin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Baldwin Quote  Post ReplyReply Direct Link To This Post Topic: Unable to connect to the running PADS application
    Posted: 03 Aug 2017 at 3:30pm
I just installed PADS VX.2.2 and now my Library Expert Pro gives me the message "Unable to connect to the running PADS application".  Any ideas on how to correct this?  Running Version 2016.14
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 3:41pm
I assume it was working before, yes?
I would make sure you're running the new PADS as Run as Administrator. Usually it can be tied right into the shortcut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Baldwin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 3:47pm
Yes it was working before.  I did "run as admin" and it still did not work.  I opened a SR with Mentor, but I need to use it now.  Back to the old days of manual creation for now until they get back with me.
Dave
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2017 at 4:41pm
Make Sure the footprint editor is also run as administrator.
This page was generated in 0.215 seconds.
