  New Posts New Posts RSS Feed - FP Designer Hole Size Issue
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: FP Designer Hole Size Issue
    Posted: 31 Jul 2017 at 6:01pm
In the Footprint Designer. if you change the hole size and regenerate the pad stack, thermal and anti-pads are not recalculated correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 7:34pm
We'll have to wait on this one until Jeff gets back from vacation on Monday August 21.
In the meantime, all the values are user definable manually until the automatic functions are fixed.
What I would do as a workaround, create a new pad stack with the correct Hole Size and delete the wrong one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2017 at 6:59am
Thanks Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 7:07am
Assuming you mean the pad stack manager (not pad stack designer) - where you can individually and directly change any element of a pad stack - the thermals are not recalculated.  In fact nothing is calculated.  All pad stack component changes must be manually entered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 7:11am
It is in FP designer. When you enter a new thru hole padstack the thermals and anti-pads are calculated. When you change the hole size they are not recalculated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 7:18am
When you change the Hole Size where?
  1. The Pad Stack Designer?
  2. The Pad Stack Manager?
The pad stack should always update if when you change the Hole Size in the Pad Stack Designer.
The Pad Stack Manager is to allow the user to "Off-Road" and ALL pad stack values must be manually changed.
This is a feature, not a bug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 7:26am
OK. Understand. I did not realize there were two screens that looked the same but operated differently.
This page was generated in 0.176 seconds.
