  New Posts New Posts RSS Feed - Library Expert 2017.16 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.16 Released!!
    Posted: 26 Jul 2017 at 9:04am
Version 2017.16 was just released!!
NOTE!!!
  • Some Drafting issues were broken in V2017.15. We advise that you discontinue the use of that release and update to V2017.16 ASAP.
FIXED:
  • Calculator:
    • Fixed an issue with the Courtyard Excess mapping to the Nominal package body and changed to Maximum package body
    • Axial Lead component family – fixed an issue with the Contour Courtyard
    • Fixed an issue with missing Component Outlines on all Grid Array component families
    • Fixed an issue where the Component Body Outline got changed from Nominal to Maximum mapping
      • Note: the default Component Body Outline should be Nominal
  • 3D STEP:
    • Removed Secondary Body color and updated the graphic image for CFP and CQFP
  • PADS to FPX:
    • Fixed an issue that was causing the FPX not to display the Associated Copper Thermal Tab
    • Fixed an issue with the PADS p/d import feature relating to outer and inner layers
    • Updated Viewer so that large parts do not get clipped
This page was generated in 0.283 seconds.
