  New Posts New Posts RSS Feed - Gang Mask - SOP Most Density Solder Mask
jmeinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmeinert Quote  Post ReplyReply Direct Link To This Post Topic: Gang Mask - SOP Most Density Solder Mask
    Posted: 20 Jul 2017 at 11:39am
When I create a SOP package at Most density the solder mask is larger than I what my setting is.
My solder mask X & Y is +- 0.05
padstack created is r135_48m145_65
should be r135_48m145_58.
Please help understand what is going on.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 11:44am
Can you send me the FPX file so I can review?
I need to check if the program is expanding the mask to Gang it.
If the Nominal Density Level it may not Gang the mask because it does not violate the Minimum Solder Mask Web rule. But Most Density the Pad Size is larger and the solder mask might swell to Gang it together.
This page was generated in 0.187 seconds.
