  New Posts New Posts RSS Feed - Library Expert 2017.15 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.15 Released!!
    Posted: 14 Jul 2017 at 3:20am
Version 2017.15 was just released!!
NEW / ENHANCED:
    • Right Mouse Button on any cell and select – Search the Web > Google
      • This new feature auto-generates the Google search engine string for the Part Number; the primary use for this feature is to quickly locate the Datasheet link
    • FP Designer: Export > Pins to .CSV file; this new feature creates a report of all pin names and their X, Y coordinate
  • Added PADS Professional CAD tool format - https://www.pads.com/professional/
  • Added “Filter” to these component family Calculators and 3D STEP models: DFN2, DFN3, DFN4 and SOFL
FIXED:
  • Calculator:
    • Fixed a Courtyard issue when relocating the Origin to Pin 1
    • Updated the thumbnail graphic image for the Through-hole Radial Round LED
    • SIP component family – Fixed a regression issue that was introduced updating the DIP Socket
    • Updated the thumbnail graphic image for the Through-hole Radial Electrolytic Capacitor
  • Altium:
    • FP Designer parts with bottom side SMD pads were not translating correctly
    • Fixed an issue with slotted holes with rectangle pad shape not rotating correctly
    • Adjusted the STEP model generation to set the State Identifier
    • Adjusted the output to be able to use multiple pieces of Solder Mask in a Pin
      • Used for Solder Mask Defined Thermal Pads
  • PADS to CAD:
    • Fixed an issue where Top Layer Pieces weren’t mapping properly
    • Fixed an issue where Multiple Top Layer Pieces in a single Footprint weren’t converting properly
  • Xpedition:
    • Updated the Import instructions - Here
  • 3D STEP:
    • SIP component family – the 3D STEP did not account for the “E1” dimension offset
    • Radial Electrolytic – rotate model 180 degrees so that the Polarity Strip is on Pin 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 11:09am
There was Contour Courtyard regression for Quad family packages.
This issue was fixed 24 hours after the preliminary release.
Download and install the latest version - www.pcblibraries.com/downloads
