  New Posts New Posts RSS Feed - IPC Class
IPC Class
jmeinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmeinert Quote  Post ReplyReply Direct Link To This Post Topic: IPC Class
    Posted: 23 Jun 2017 at 10:56am
What class level (1, 2, 3) are the footprints designed to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 1:19pm
Library Expert produces library parts for all 3 IPC Classes. The fabrication class code is mostly defined by through-hole pad stacks and not SMD pad stacks and Library Expert supports every standard SMD component family and they are good for all 3 IPC Classes. Other than the standard DIP, SIP and Header, most connector land patterns are created using the mfr. recommended pattern in Library Expert Pro.
IPC Class 1 - General Electronic Products – Includes limited life products suitable for applications where the requirement is function of the completed product.
IPC Class 2 - Dedicated Service Electronic Products – Includes products where continued performance and extended life is required, and for which uninterrupted service is desired but not critical.
IPC Class 3 - High Reliability Electronic Products – Includes products where continued high performance or performance-on-demand is critical, product downtime cannot be tolerated, and the product must function when required.
IPC-7351 3-Tier Density library system:
Density Level A: Maximum (Most) Land Protrusion – For low-density product applications, the ‘maximum’ land pattern condition has been developed to accommodate wave or flow solder of leadless chip devices and leaded gull-wing devices. The geometry furnished for these devices, as well as inward and ‘‘J’’-formed lead contact device families, may provide a wider process window for reflow solder processes as well.
Density Level B: Median (Nominal) Land Protrusion – Products with a moderate level of component density may consider adapting the ‘median’ land pattern geometry. The median land patterns furnished for all device families will provide a robust solder attachment condition for reflow solder processes and should provide a condition suitable for wave or reflow soldering of leadless chip and leaded gull-wing type devices.
Density Level C: Minimum (Least) Land Protrusion – High component density typical of portable and hand-held product applications may consider the ‘minimum’ land pattern geometry variation. Selection of the minimum land pattern geometry may not be suitable for all product use categories.
This page was generated in 0.719 seconds.
