  New Posts New Posts RSS Feed - Assembly drawing in Altium
sinistry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sinistry Quote  Post ReplyReply Direct Link To This Post Topic: Assembly drawing in Altium
    Posted: 16 Jun 2017 at 12:15am
Hi
I wonder if there is another way of getting the assembly drawings to behave the way I want?
Perhaps there is a bug or Library expert doesn't support Altium all the way?
Do I really need to manually delete layers in my Altium library and setup layer pairs in order to have a printable assembly drawing?
Assembly outline can be set to different layers within Library expert.
Then in Altium you have to define these layers as a layer pair in order to have the assembly outline follow the component when switching from top to bottom layer placement.
When defining different layers for the reference designator in Library expert the designator shows up on both top and bottom layers. Is this a bug?
I want the Assembly outline and assembly designator on the same mechanical layer, following the component when switching from top to bottom placement.
In order to achive this I have to define the same mechanical layer for assembly outline and reference designator in Library expert for top layer.
Then add the same mechanical layer in the empty box for bottom reference designator as the bottom assembly outline has.
And then in my Altium library I have to manually delete the designator-text from my reference designator bottom layer (Since it shows up on booth top and bottom ref.des layers).
And finally set up a mechanical layer pair for the assembly ouline/ref.des top and the assembly ouline/ref.des bottom.
Now the assembly drawings behave and prints the correct way.
This is how I have set up the layers.
Kind regards / Johan
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2017 at 1:39pm
Huh? Not seeing it. I use your layers and get designators on the specified layers. I see no added text on top and bottom. Which version of the Lite are you using?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sinistry Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 10:44pm
Hi
I have tried it in both 2017.13 and 2017.14.
However I found another way of getting it right with a little less manual effort.
If I leave the fields for bottom assembly and ref.des empty in Library expert and define the same layer for top assembly and ref.des there are nothing that needs to be deleted in my library. All I have to do is define layer pairs in my Altium project. So I'm pairing the assembly/refdes top layer from Library expert with an empty mechanical layer in Altium.
That worked fine. All you need to do is defining the layer pair in Altium. But that is only done once for each project and no extra manual work needs to be done for every component created by Library expert.
This page was generated in 0.346 seconds.
