  New Posts New Posts RSS Feed - FP Designer output pin locations
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: FP Designer output pin locations
    Posted: 14 Jun 2017 at 7:58am
Is it possible to also output the pin locations to a CSV file ? This would make it much easier to verify pin locations and also allow changing pin locations for a new part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 8:16am
FP Designer can import pin names and locations in a .CSV file -
http://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=10.5
So I think it would be easy to reverse that process.
It would be a good feature for expediting quality control.
I'll ask the programmer in charge of that feature to add it to Library Editor > Tools > Export Pins to .CSV
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 8:18am
Thanks Tom.
