  New Posts New Posts RSS Feed - How to make the DPAK?
Kenji View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenji Quote  Post ReplyReply Direct Link To This Post Topic: How to make the DPAK?
    Posted: 07 Jun 2017 at 7:09pm
uploads/11773/IPB180N04S4-01.pdf
Hi. I have a problem that the package have a 6pin + tab pin. But only Here(Surface mount) can select the 6pin.
If 6pin is selected, Couldn't leg's pin move?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 7:18pm
Are you using the V2017.14 pre-release - www.pcblibraries.com/downloads
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenji Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 8:14pm
I don't download the V2017.14
It doesn't exist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 8:22pm
With V2017.14 pre-release you can Hide, Delete and rename DPAK pins.
Select the middle pin and Right Mouse Click and select "Hide" or "Delete".
