  New Posts New Posts RSS Feed - Idea For Easy Component Orientation Setting
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: Idea For Easy Component Orientation Setting
    Posted: 29 May 2012 at 2:25am
The PCB Footprint Expert lets me change the orientation per component in Setup Components for each individual component type which is nice but it would also be nice if you could globally change all components to match either Level A or Level B orientations in one go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2012 at 8:33pm
You can create different .dat files and define any preferences you want in each one.
The DefaultPreferences.dat file is defaulted to IEC Rotation.
There is another .dat file in your folder named - IPC-7351B_DefaultPreferences.dat (which defaults to IPC rotation)
Try it out and let us know.
