  New Posts New Posts RSS Feed - About the POD?
About the POD?
Kenji View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenji Quote  Post ReplyReply Direct Link To This Post Topic: About the POD?
    Posted: 12 May 2017 at 1:27am
I'd like to know, You do make the FPX file every year?
FPX file has a limited number on the POD?
If FPX file has a limited number on the POD, shoud i order to download the new FPX file?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 2:27am
The FPX files are generated on each download. If we implement any new features that can get incorporated into the FPX files, the new changes will be available in the new format. Any older FPX formats will continue to be compatible with newer Library Expert software.
There are currently over 1 million parts on POD and we're looking at making available a LOT more via subscription in the very near future. If the part(s) you need do not exist on POD, you can request them for 5 POD Credits each. Don't forget about the BOM Service - www.PCBLibraries.com/LibraryExpert/BOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenji Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 11:46pm
So,  If the part(s) I need do not exist on POD, should it only request?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 12:13am
Yes, you would need to request.
If you have the latest Library Expert version, you can also use the complimentary BOM Service: www.PCBLibraries.com/LibraryExpert/BOM
