  New Posts New Posts RSS Feed - Mirroring BGA's
Mirroring BGA's
richardprent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote richardprent Quote  Post ReplyReply Direct Link To This Post Topic: Mirroring BGA's
    Posted: 10 May 2017 at 8:08am
We are facing problems with BGA's while creating 3D step and the generation of the  placement courtyard.
  1. When you create a BGA and use the mirror pin function the  3D step pin 1 indication is fault.
    It does not mirror but stays in the original place.
  2. the courtyard access is to small, it is equal to the component body instead of 1mm larger.
Regards Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 8:15am
Mirroring BGA's is typically used for seeing the Bottom Side to make it easier to depopulate pads.
There is no such thing as a Mirrored BGA, so do not save mirrored BGA's to FPX.
Send me the link to the datasheet so I can reproduce the courtyard issue.
Tempest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tempest Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 5:54pm
Hey Tom,
I've run into this BGA pin one location a couple times now, got bit pretty hard on the Altera one since no one caught it.
Another just came up that would have been nice to move the pin one location on the bga also but that is just not an option, maybe it should be.
The two examples are here...
We were really surprised by the Altera pinout, I personally think someone mirrored a pinout diagram and didn't want to fix their documentation or the like so they just flipped the mechanical.
Paul Hinchcliff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 6:34pm
I can relate to your situation, but the Mirror feature is exclusively for seeing the "Bottom Side" for the sole purpose of matching the datasheet to depopulate pins.
You must un-mirror the BGA prior to putting into your FPX file.
The feature that you need is Alphanumeric Rows or Columns -
