  New Posts New Posts RSS Feed - Library Expert 2017.12 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.12 Released!!
    Posted: 08 May 2017 at 12:19pm
Version 2017.12 was just released!!
NEW / ENHANCED:
  • All versions of Library Expert Lite, Viewer, IPC, Builder and Pro:
    • Added Part Number Search for component availability using the Octopart search engine
  • Library Expert Lite now fully supports 3D STEP export
    • User color control
    • Vertical Axis control
    • Nominal or Maximum Material condition control
    • Through-hole lead depth control
FIXED:
  • Preferences:
    • Added the SOFL to Component Families
    • SOFL component family – retrieving SOFL data from FPX into the Calculator did not work
  • 3D STEP:
    • Fixed an issue with SOFL not producing a 3D STEP file
    • Added new color assignments for the Chip Filter component family
  • Xpedition:
    • Fixed a rotation issue with complex paste mask
  • PADS Layout:
    • Fixed a problem with the importer that was inverting the corners of chamfered pads
    • Provided the ability to import donut shapes properly
    • PADS p/d Viewer – Provided the ability to display donut shapes
This page was generated in 1.094 seconds.
