  New Posts New Posts RSS Feed - No Tools menu in Library Expert Lite 2017.11
PLTcbv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Topic: No Tools menu in Library Expert Lite 2017.11
    Posted: 13 Apr 2017 at 1:00am
I've downloaded the Library Expert Lite 2017.11 and was surprised that the Tools menu was removed.
I often use the Pad Stack Designer and sometimes the Hole Size Calculator and Axial Lead Form Calculator.
The Pad Stack Designer is very handy when old Pad Stack names are used in an old design and I want to generate the new IPC-name by filling in the Pad Stack Designer.
Please consider for the next time a menu function or option is removed from the free Library Expert Lite software to state this in the Release Notes like:
NEW / ENHANCED:
FIXED:
REMOVED:
jgregoire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jgregoire Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:07am
I'm running 2017.11, and the Tools menu is right where it has always been.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:17am
We were trying to make room in the Main Toolbar for the new Octopart Search engine.
What would you rather have?
Tool Box or Octopart search?
Or both? :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 11:49pm
I have looked carefully on opening 2017.11 and I noticed that the Tools icon"flashes" and disappears under the Free Parts icon.
So it seems that the icon bar is fixed at some point.
I'm using 2  24" screen with resolution 1920 x 1200
If I can choose for the main toolbar I would have both items.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2017 at 6:11am
OK, we'll try to add both features back in V2017.12 Library Expert Lite.
Also, these is another BIG surprise coming with V2017.12 next week that I'm sure everyone will enjoy.
pzt648485640 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pzt648485640 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 12:57pm
There is no big surprise; DPI problem is estimated that the existing model can not be resolved; suggest that you use WPF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 1:04pm
V2017.12 will be released next Monday May 1, 2017.
V2018 is being written in WPF (Windows Presentation Foundation) and C# and it will be the premier PCB library tool in the electronics industry. New feature's like schematic symbols, irregular pad and body shapes, interactive graphic editing, open multiple parts simultaneously and much more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pzt648485640 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 1:39pm
Thank you! Tongue
V2018 language pack support should be added
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 12:07am
Checked V2017.12 LITE version and the Tools menu is showing again.
Thanks for fixing and the new Octopart search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 5:31am
What about the new Lite 3D STEP feature?
Did you try it yet?
This page was generated in 0.766 seconds.
