  New Posts New Posts RSS Feed - Cadence Text Block Selection
craig4tone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Topic: Cadence Text Block Selection
    Posted: 07 Apr 2017 at 8:20am
We have custom text blocks defined for Silk and Assembly.  We would like the ability to map a text field to a text block in the Output dialog box.  It would also be nice to disable the Device Type text.
jgregoire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jgregoire Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 11:32am
I second this.
Every foot print we create, we change the Assembly and Silkscreen RefDes size, and delete the Device Type text.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 11:37am
I would highly suggest writing an Allegro post-process script to automate cleanup of elements to your specific custom setup. Custom mapping of textblocks is something we likely would not handle in the translator.
This page was generated in 0.209 seconds.
