  New Posts New Posts RSS Feed - Padstack naming
Padstack naming
magnus.lictor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Topic: Padstack naming
    Posted: 06 Apr 2017 at 12:28am
I want to rename the padstack, so that it complies with the padstacks we already have in our library.
c45 --> SM Round 0.45
This is changed by the software to "SM Round 0_45"
Is there a restricting on the padstack naming?
Regards,
Charles
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 8:11am
You cannot rename pad stacks in the Calculator.
However, you can rename pad stacks in FP Designer.
So, create the part in the Calculator and then move it to FP Designer, rename the pad stacks and save the part to FPX.
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 11:57pm
Are you sure?  The button is there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 12:13am
And I can really change the name,  only the .  is changed to a _
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 7:18am
Library Expert has rules established in the IPC-7351 Pad Stack Naming Convention here -
If you want something different, this would be a "New Feature" that would have to be requested here -
I'll see if I can get this pushed up to the top of the New Feature list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 1:12pm
At this time, our programmers are reluctant to add a period to the pad stack naming convention for fear of regression bug issues and not being able to support other CAD tools.
We'll pick this up again for the V2018 release.
This page was generated in 0.408 seconds.
