  New Posts New Posts RSS Feed - Is PCB Repair a beneficial than buying new PCB?
Anderson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderson Quote  Post ReplyReply Direct Link To This Post Topic: Is PCB Repair a beneficial than buying new PCB?
    Posted: 24 Mar 2017 at 11:07pm
No doubt, modern electronics have many PCB's and they many times they fail. The common faults that occurs are burn-outs, blown tracks and failed components.
Does repairing PCB's save you money and is beneficial for your customers?
DarnellBroten View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarnellBroten Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 6:12am
Yes, circuit boards could be repaired but I believe you should prefer to get the services of the best skilled person.
However, it also depends on the condition of PCB either it could be repaired or not.
Otherwise, you would have to go with a new purchase option.
RonaldSmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RonaldSmith Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 3:37am
It depends on how much money it will take to repair your PCB, if you can buy a good PCB for that much money then there is no benefit to repairing the PCB. Otherwise in general repairing a PCB is much cheaper than buying a new PCB.
This page was generated in 0.452 seconds.
