  New Posts New Posts RSS Feed - Polarity by Component Type
craig4tone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Topic: Polarity by Component Type
    Posted: 07 Mar 2017 at 1:46pm
Adding polarity to Assembly is all or nothing.  It would be nice to be able to add polarity by component type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 1:52pm
You have 8 different Polarity Marking options.
You can set the shape, size, location, layer, filled, not filled, rotation, etc.
Watch this video:
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 1:45am
I think what Craig is saying is that its either added to all or not on all footprints and he wants to be able to define the polarity marker to be added or not by component type.
Not the type or indicator but its presence.
Why, I am not entirely sure - Craig - can you exand on that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 11:37am
That is correct Matthew.  I can't add a chamfer to the corner of a single QFN assembly layer unless it is all components and types (QFN, BGA, SOIC, etc.)
We like to chamfer BGA but put a hollow circle on SOIC for example.  Right now I can manually add the hollow circle but no way to automatically chamfer the corner of the assembly outline unless it is enabled for all components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:29am
So you want the ability to turn on/off Legend and Assembly Polarity markers per component family instead of All or Nothing and the ability to select the Legend and Assembly Polarity Marker instead of just having a Dot for Legend and a chamfer for Assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 5:19am
Yes.  For example, I want to tailor the polarity as follows:
- SOIC - Legend dot, Assembly dot
- SON - Legend dot, Assembly dot
- QFN - Legend dot, Assembly dot
- BGA - Legend chamfer, Assembly chamfer
There are some cases with the <0.5mm pitch parts where a dot is too large so we want the ability to override at the component level and chamfer instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 7:51am
We like the user to manually insert every Polarity Marker with the Shape, Size and Location that you need and save to FPX. This is the main reason why we do not manually add Polarity Marking to Calculator parts that are on POD. We have no idea if the user want's a Triangle, Square, Dot, Plus or where the user wants to locate it or what size the user wants.
The Auto-generation of Polarity Marking is very complex to control the Shape, Size and Location for every component family and auto-size the Polarity Marker per the package size.
We'll see what we cab do to automate V2018.
