  New Posts New Posts RSS Feed - SMD Crystal Naming Convention
BennsPCB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Topic: SMD Crystal Naming Convention
    Posted: 06 Feb 2017 at 4:01am
Hi guys,
the naming of Crystal SMD footprint in LE differs from B and proposed C versions of 7351 doc.
from (proposed) IPC-7351C:
Crystals (2 leads) ................................XTAL + Body Length X Width X Height + L Lead Length X Width
from LE Pro:
XTAL1150X490X350D1300L416X6 4N
I guess the "D1300" is a kind of  "toe to toe" nominal dimension.
Where can I find this difference/addition documented?
Cheers,
/Benn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2017 at 9:08am
For "Under-Body Outward L" terminal leads, there are 3 dimensions for pad pattern calculation and they are highlighted with a Blue dot and the Note says "Enter 2 of the 3 optional dimensions. Different combinations may result in a slightly different footprint size".
  • D
  • D2
  • L
The Land Pattern Name reflects which 2 of these 3 options you selected.
Note: if you enter all 3 dimensions, the resulting land pattern may be too large due to the tolerances of all 3 values.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 1:15am
Thanks for the explanation Tom!
I do see the point of using this measure in the footprint naming, and perhaps this should be suggested to the IPC guys.
Cheers,
/Benn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 8:07am
We did mention to the IPC land pattern committee, but they are trying to introduce a brand new JEDEC naming convention for the next release.
PCB Libraries, Inc. will be rejecting the new JEDEC naming proposal as it's 100% different and complex and only one committee member from Mentor Graphics is promoting this major change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 12:49pm
hmm, there's a difference in common sense and Mentor sense.
Why make the simple hard, when you can make it impossible. Wink
This page was generated in 0.262 seconds.
