  New Posts New Posts RSS Feed - Offset
Offset
craig4tone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Topic: Offset
    Posted: 10 Jan 2017 at 10:00am
I'd like the ability to select a shape and or a group of pins and apply an offset.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:51am
This feature will be in V2018.
The way it works is that when you select a group of pins, if they all have the same "Y" coordinate you will be able to edit that value and have the group move.
However, if the group of pins have different X/Y coordinates I'm not sure if you can offset them by a coordinate. You will have the ability to click and drag and snap to a grid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 5:13am
I think that would suffice.  When I put the ER in, I was struggling with a large pin count QFN and had to do each pin individually.  If I can grab an entire row and apply a new coordinate, that will be helpful.
