  New Posts New Posts RSS Feed - Offset Outline or All Pins
craig4tone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Topic: Offset Outline or All Pins
    Posted: 10 Jan 2017 at 9:09am
I made a mistake and made a bunch of connectors with the pins centered about the outline.  The outline needs to be offset +0.89mm from center.  Is there a way to offset all of the pins down by that amount or the outlines up by that amount or must they be re-created?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 9:21am
You either have to delete and re-insert or double click each pad and change the coordinate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 9:24am
Ouch ... there are a few asymmetrical mounting pads.
There is a feature request then ... Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 9:52am
Use the Pins / Import feature.
Watch this video:
If you do not have the latest Help file, delete the PCB Library Expert 2017.chm file in this folder:
C:\Program Files (x86)\PCB Libraries\Library Expert 2017
Then reopen Library Expert > Help > Download Help
There are 70 new videos that teach every feature in Library Expert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 10:00am
They aren't that complex ... almost a wash in time.
