  New Posts New Posts RSS Feed - Board Edge
Board Edge
craig4tone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Topic: Board Edge
    Posted: 09 Jan 2017 at 7:11am
Several connectors, modules, etc. specify the PCB Edge.  It would be nice to have a line draw feature for PCB Edge that can be mapped to a user-defined layer on export.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 8:56am
We already have the ability to insert a Line with a user defined length, width, location and rotation.
But you're asking for more Layer assignments beyond Legend and Assembly.
Is the Drill Drawing layer good enough? The reason is that Library Expert interfaces to 23 CAD tools and we need layers that they all have in common. I think every CAD tool has a Drill (Fabrication) Drawing  layer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 5:15am
That was why I suggested the ability to create a layer in Library Export that is normally ignored unless it is mapped in the Build process and mapped to a specific layer.  I.e. it puts the responsibility on the user to map it to the correct layer dependent on tool flow used and the existence of that layer in that flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 8:27am
Any updates on this?  We are running into more and more instances where we might want to put notes or sketches on a layer other than Legend or Assembly.  We typically map to a DESIGN_NOTES layer.  Parts such as sensors, LEDs may have specific layout requirements that we like to capture in the footprint besides PCB edge on connectors.  Ideally, we want this data in FPX so we can export to the multiple tool chains that we utilize and the data is consistent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 8:33am
V2018 Library Expert is stable and only selective new features are being added and all bugs are being fixed.
All PCB Libraries programming effort is involved in the development of a complete 100% rewrite in V2019 that will also include schematic symbols.
You will have increased flexibility in V2019 to do whatever you want for any Standard or Non-standard package and Connectors.
cioma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cioma Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 1:31am
A bit off-topic: if V2019 will be completely rewritten, is it possible to make it cross-platform (Windows, Linux, MacOS)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2018 at 7:32am
I'm not sure. The code is being written in C# for the foundation with WPF (Windows Presentation Foundation) for the forms.
The new rewrite will be the best program we ever created in the past 15 years and it will be in development years after we release it.
This page was generated in 0.389 seconds.
