  New Posts New Posts RSS Feed - Spacing of Adjacent Holes
Gary K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary K Quote  Post ReplyReply Direct Link To This Post Topic: Spacing of Adjacent Holes
    Posted: 21 Dec 2016 at 12:08pm
IPC-2221A 9.2.7 states that the "residual laminate material" be no less than 0.50 mm (20mil).
This translates into hole to hole clearance, or hole to hole spacing.
I don't have access to IPC-2221B which is the current rev as of November 2012.
Can someone post whether the value has changed in IPC-2221B?
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 4:52am
The values are the same in the rev B standard.
