  New Posts New Posts RSS Feed - Saving custom dimensions values
elenkoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elenkoy Quote  Post ReplyReply Direct Link To This Post Topic: Saving custom dimensions values
    Posted: 12 Dec 2016 at 12:32pm
For some specific components I have to manually modify values for Toe/Heel/Side under the Density Level tab. Then I save the footprint to my FPX. If later I open that footprint for verification or comparison, these value are set back to the default.
What should be or can be done in order to save the part with the custom values?
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 12:53pm
There are several versions of Library Expert.
Pro saves all preferences and Lite does not have Preferences or FPX files.
The LE Pro FPX file only saves the Component Dimensions and/or Mfr. Recommended Pattern data.
Everything else is saved in your personal preference file, unless you are using LE Lite, there are no user preference files.
What version of Library Expert are you using?
Post Options Post Options   Thanks (0) Thanks(0)   Quote elenkoy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 9:38am
No, it is not working, and I am using the 2017.04. I just tested it again.
I modified the toe/heel/side values, added the part to my current fpx and saved the fpx. I restarted the PCB Libraries, reopened the footprint, and the changes are gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2016 at 10:05am
The FPX file does not save Toe/Heel/Side values.
All solder joint values are stored in Preferences and you can have multiple Preference files.
Watch some videos here -
This page was generated in 0.688 seconds.
