  New Posts New Posts RSS Feed - Library Expert 2017.04 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.04 Released!!
    Posted: 09 Dec 2016 at 1:46pm
Version 2017.04 was just released!!
NEW / ENHANCED:
  • Preferences:
    • Added Oblong pad shape to these component families:
      • SOD
      • SON w/rectangle leads with and without Thermal Pad
      • QFN w/rectangle leads with and without Thermal Pad
    • Removed a restriction of 50% pad width for Chamfered pad shape, now unlimited
  • Help > Topics:
    • Added 70 new educational training videos to the program Help > Topics
FIXED:
  • Calculator:
    • In the calculator dimension panel the Drafting > Courtyard > on/off switch was disabled
  • Calculator to FP Designer:
    • Side Concave Package (2, 4-pins) swapped D & E dimensions going to FP Designer
  • Preferences:
    • Fixed an issue with SOT Pin Pitch < 0.40 mm
  • Print Feature:
    • Fixed an issue where the print feature was disabled
  • Allegro/OrCAD PCB:
    • Fixed an issue with Drafting Line Arcs not coming out as intended
    • Fixed an issue with 16.6 and earlier that was causing the suppression of the inner layers of a through-hole pad stack. V17.2 scripts are unaffected
    • Fixed a rotation issue with irregular polys when using PADS to CAD
  • PADS Layout:
    • Parts from FP Designer with pads that had corner radius on 2 sides crashed Library Expert
