  New Posts New Posts RSS Feed - POD Only Searches One Time??
dmacgreg View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dmacgreg Quote  Post ReplyReply Direct Link To This Post Topic: POD Only Searches One Time??
    Posted: 09 Nov 2016 at 2:39pm
When I use the LE Pro "Free Parts" tool it will start POD as a new tab on my FireFox browser as expected.
I can then successfully search for a part - but only one time.
If I go back to the POD tab and modify the search parameters it never responds to the search button again.
I have to start over in LE Pro to initiate a new POD search. This does not seem right.
How can this be fixed?
Thanks - appreciate your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 3:54pm
We're looking into this. For now, if you select the "Search" button on the POD results page, it will take you back and the button is not disabled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 2:21am
It looks like the issue your reported is resolved.
Can you please check and confirm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmacgreg Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 10:28am
That works as expected. Now I can search all day and still not find parts!
Your quick response is much appreciated - thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 10:33am
Can you please send me the mfr. name and part numbers that you cannot locate on POD.
There are several features you can use.
  1. Do a partial part number search
  2. Do a Case Code search
The FPX file contains the component dimensions and that is referenced to the Case Code.
All you really want is the component dimensions or the mfr. recommended pattern.
If you send me the mfr. name and part number and maybe even the datasheet link, I will tell you how to improve your hit ratio.
I'll contact you offline.
