  New Posts New Posts RSS Feed - Pad Stack Manager
Pad Stack Manager
BennsPCB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Topic: Pad Stack Manager
    Posted: 03 Nov 2016 at 4:09am
I'm creating a 4-pin SIP Hall sensor (Allegro A1363) FP and want to increase pad clearance by using an oblong pad instead of a round one, but Pad Stack Manager won't let me do that.
Why?
Cheers, ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 7:04am
You Must create this part in FP Designer.
The Calculator does not have a Oblong Through-hole pad stack option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 7:21am
OK Tom , I see. But, it seems like a 2-stage takeoff.
May I request a button that takes me to FP Designer directly (with the data already created)?
And I still want to name it acc. to IPC-std.
Perhaps with a note/naming that user defined padstack is used.
Cheers, ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 7:29am
There is a button to move your Calculator part to FP Designer.
However, these component families will not transfer - DPAK, TO220, TO92, Mounting Holes, Aluminum Electrolytic Capacitor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 7:37am
Tried that, but all data except the pins disappeared. Not very useful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 7:43am
Did you select the "Body" tab and enter the package dimensions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 8:21am
Nope, I came from Through Hole/Single In-Line Package (SIP), where I have entered all my data.
It's from here it would be useful to enter the FP Designer. (with data intact) Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 8:38am
OK, this is a bug and we're going to release V2016.14 later today.
In the meantime, you can create that 4-pin SIP in FP Designer with Oblong PTH pad stacks in less than 3 minutes.
Thank you for reporting this issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 8:47am
OK, nice Big smile
Cheers, ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 4:27pm
2016.14 is online in our Downloads section, please run it and let us know.
