  New Posts New Posts RSS Feed - Library Expert 2016.13 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2016.13 Released!!
    Posted: 28 Oct 2016 at 3:59pm
NEW / ENHANCED:
  • Calculator:
    • Added Inductor, Polarized to the Molded Body component family
  • 3D STEP:
    • Added Molded Body – Inductor, Polarized
  • Altium:
    • Added an option for Stroke Text Font
FIXED:
  • Preferences:
    • Updated the IPC-7351C Proposal.dat file. Fixed a typo in the Underbody Outward L “Terminal Preferences” for the Heel.
    • Fixed a typo in the L, N & M solder joint goals for Side Concave with Pitch > 1.27 mm
      • If you created any Side Concave library parts with a pin pitch > 1.27 mm we recommend that you recreate it
  • Parts downloaded from POD can now translate Physical Description and Footprint Names from millimeter units to mil units using “Tools > Regenerate Library”
  • Calculator:
    • Moving some parts to FP Designer were throwing exception errors
    • Fixed an issue related to Polarity Marking on some occasions not saving to FPX
    • Fixed an issue with footprint rotation turning off the “Build Part” option
    • QFN – if you had a part loaded with Thermal Tab, selecting the Clear icon did not clear the Chamfer or Radius data from the buffer
    • Fixed an issue regarding mil unit Pin Pitch rounding to whole integer when using Build Library (Batch Build)
    • Fixed an issue with SOT23 Gang Mask
    • Added Chip, Molded Body and MELF to the list of parts that can go from Calculator to FP Designer
    • Fixed an issue with SOT143 producing double Legend outlines
    • Added Diodes to SOFL component family?
    • Legend trimming issue, caused by basic flaw in the trimming algorithm, allowed Legend on pads; issue only occurred when Legend Line Width and Gap Space were different values
  • Allegro/OrCAD PCB:
    • When using version 15.7, the program will shorten any pad stack names over 18 characters, to 18 characters, which is the maximum length for pad stack name that that tool supports
  • PADS Layout Translator:
    • Fixed an issue with the program creating an XML file on each CAD library output
  • Documentation:
    • Updated IPC-7351B and IPC-7351C Proposal Excel spreadsheets in the Documents folder, Version 1.4
    • Updated Library Expert Surface Mount Families PDF file
This page was generated in 0.299 seconds.
