  New Posts New Posts RSS Feed - Pin 1 Dot on Pads
Pin 1 Dot on Pads
GrungyRemnant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Topic: Pin 1 Dot on Pads
    Posted: 22 Sep 2016 at 7:08am
It seems there are Pin 1 dot issues on 2 pin polarized parts.  The pin 1 dot is on the pad.  I’ve noticed it with the following families:
 CHIP – Polarized
MELF
Molded Body
SODFL
 Is there a preference setting causing this?  I don’t see any control over the position in the preferences besides Legend Outline Placement Roundoff.  But I don’t want to change that value as it changes all the Silk lines as well as the pin 1 dot.  It is currently set to 0.01 which is the default I believe.
This problem is present in version 2016.10 and 2016.11  Can this be corrected with a setting change or is it a bug?  See image below of a demo polarized chip cap.
Regards,
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 8:30am
This issue has been fixed in the latest V2016.11 pre-release - www.pcblibraries.com/downloads
Let us know if you have any further issues and thank you for reporting this issue.
