  New Posts New Posts RSS Feed - Allegro Component Outline/Terminal Issue with Chip
GrungyRemnant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Topic: Allegro Component Outline/Terminal Issue with Chip
    Posted: 22 Sep 2016 at 7:03am
Hi.  When importing into Allegro and sending the Component outline, including terminals to the CAD output there is a problem with Chip parts.  I haven't noticed this issue with the other families.
The outline/terminal line is incomplete.   Please see the attached image comparing the PCBLEP expected output to the actual Allegro import.  Note the missing line.  There should actually be 3 separate line paths with 4 segments each, 1 for the outline and 2 for the terminals.   Can this please be corrected?
This problem is present in version 2016.10 and 2016.11
Regards,
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 3:39pm
i'll take a look at it.
Have you actually moved that terminal outline and ensured the bottom part isn't actually there? It could be a graphical issue on Cadence's part. I find it highly unlikely that the component rectangle itself isn't fully formed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 7:45am
Hi Chris.  Yes I confirmed it’s not a graphical issue.  I looked into it a little more and found the problem.  The problem is actually two fold.
The first problem is you are sharing lines at the body start/end vertex.  While your script pick points are correct Allegro will merge lines when picking the start/end of a path.
Below are the script lines in question, I’ve added the allegro command line feedback as a comment where the problem occurs (“Merged with existing line. Start next line.”) . As soon as the left terminal picks the lines start/end they merge and the line disappears.  The remaining 2 vertices are added as a new separate line. The right terminal doesn’t have a problem because it never picks the start/end point.
I believe the only way to avoid this would be to have the component body rectangle start/end away from the terminal picks, ie in the middle somewhere.  You’ll see the same issue with Oscillator, Corner Concave for example since the pins are at the corners.
Having all of that, lol, there is an allegro environment variable that can correct this:
         addline_nomerge
The default value is to have this unset.  When unset the problem described above manifests its self.   When you set this variable there will be no issue with the line drawings.  To set or unset it type the following at the Allegro  command line:
     set addline_nomerge
     unset addline_nomerge
Hope this helps.
Chris
Script snippet:
# Graphics
add line
setwindow Form.mini
FORM mini lock_direction Off
FORM mini class PACKAGE GEOMETRY
FORM mini subclass DISPLAY_TOP
FORM mini line_width 0.001
setwindow pcb
pick -1.6 -0.8
pick -1.6 0.8
pick 1.6 0.8
pick 1.6 -0.8
pick -1.6 -0.8
done
add line
setwindow Form.mini
setwindow pcb
pick -1.1 0.8
pick -1.1 -0.8
pick -1.6 -0.8            #Merged with existing line. Start next line.
pick -1.6 0.8
pick -1.1 0.8
done
add line
setwindow Form.mini
setwindow pcb
pick 1.1 -0.8
pick 1.1 0.8
pick 1.6 0.8
pick 1.6 -0.8
pick 1.1 -0.8
done
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 10:56am
so I can just use:
set addline_nomerge    at the start of adding the graphics
and:
unset addline_nomerge   at the end.
And everything will be good? :> That's easy enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 11:11am
Made the update and confirmed it works, it'll be in the next pre-release. Thanks for narrowing this down.
·         Allegro/OrCAD PCB – Added a command which turns off the line merge capabilities of Allegro during Graphic placement, and another that turns it back on when done. This should prevent component outlines from accidentally merging with terminal outlines and causing graphical issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 11:27am
That would work, unless the user has it set in the first place then you are changing it on them. :) However  I would say it's a small price to pay to ensure the scripts work.
The other option would be some skill commands at the start and end of the script to get current setting, change it, then restore the user setting at the end.  Example script where variable user_addline_nomerge is the users existing setting:
skill
(user_addline_nomerge = axlGetVariable("addline_nomerge"))
(axlSetVariable("addline_nomerge" t))
(exit)
# Allegro Script
 <regular script contents here>
#END
skill
( unless(user_addline_nomerge axlUnsetVariable("addline_nomerge")) )
(exit)
Regards,
Chris B
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 11:52am
skill scripting is only available on full Allegro and not OrCAD PCB, so i'll stick with what we have unless someone complains about the setting. How do you prefer it?
In all likelihood, I think it would be more likely that they'll want it set to not merge, but you know far more about Allegro than I do, what is the best setting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 12:02pm
Very good.  Smile
I think your solution is completely acceptable as it restores the default value (unset) after running the script.  The variables effect on the designer is quite minimal.  I would guess most users are probably not even aware of this user preference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 5:25pm
A new V2016.11 pre-release is ready to test - www.pcblibraries.com/downloads
