  New Posts New Posts RSS Feed - STEP File Extension .stp in Addition to .STEP
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: STEP File Extension .stp in Addition to .STEP
    Posted: 20 Sep 2016 at 9:01am
Would it be possible to have a user preference for the user to select the .stp file extension for STEP files rather than .STEP?
I have found some tools that, for some reason or another, don't see .STEP files until they have been renamed to .stp
Post Options Post Options   Thanks (1) Thanks(1)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 1:46pm
i'll see what I can do.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 5:15pm
Library Expert V2016.11 pre-release has been updated with this new feature - www.pcblibraries.com/downloads
Here is how it works -
·         3D STEP:
o   3D Model output now has a checkbox option ‘Use .STEP’. If this box is checked, you will get .STEP extensions for 3D model files. If it is not checked, you will get a .STP extension. The default is on but can be set using the "Save Entries As Preferences".
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 12:36am
Thanks all.
