Forum Home Forum Home > Libraries > Footprints / Land Patterns > Xpedition
  New Posts New Posts RSS Feed - Export Parts - Configuring Assigning Layers
AP-EXAD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AP-EXAD Quote  Post ReplyReply Direct Link To This Post Topic: Export Parts - Configuring Assigning Layers
    Posted: 14 Sep 2016 at 3:04am
I am using PCB Library Expert V2016.10
Are there any possibility to configure assigning PCB Library layers to Expedition layers?
i.e.:
  • Component Outline will not be exported?
  • Terminal Outline will be exported to "User Draft Layer"
Thank you
Andrej
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 5:29pm
If you don't want something like Component Outline exported, that should be an option in FPX.
As per user-definable layers? The Expedition Ascii doesn't really support that. Everything is specific layer callouts, which is why they weren't settable in the first place. I mean, unless you turn them all into graphics, but I don't see the point.
As per putting out the Terminal Outline to a User Draft Layer? Those I could see turning into graphics. I can look into that. Right now it appears those are shifted to assembly outlines, which was probably sketchy in the first place. Having them be graphics on a user layer name specified seems reasonable, and if ASSEMBLY_OUTLINE is specified it gets shifted to assembly.
This page was generated in 0.309 seconds.
