  New Posts New Posts RSS Feed - No Support for DFN IC's?
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Topic: No Support for DFN IC's?
    Posted: 15 Aug 2016 at 8:28am
Hello, IPC-DRM-18H page 60 has DFN (Dual Flat No Lead) packages.
For an IC such as pdfserv.maxim-ic.com/package_dwgs/21-0137.PDF with multiple pads either side these are not within the LEP.
SON with tab seems the nearest, is this the correct one to use for this package please?
Also is there any sort of list that says which LEP family to use for which known as family?
Thank you
Matthew
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 9:37am
This package is not a DFN (although that is what the Mfr. calls it).
JEDEC and IPC call this a SON w/Tab.
The main documents that explains all the package names and solder joint goals are here -
Download "Surface Mount Component Families"
Note: there was a major update to this document this last weekend and we're all waiting for it to post today. It has 10 additional pages of information and the new IPC-7351C (Proposed) solder joint goal tables and updated land pattern images.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 12:44am
Cheers Tom, Thumbs Up
The correct one was chosen then, I'll scribble on my IPC-DRM-18H book. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 6:47am
Tom is the latest pad naming convention document also available?
I cannot find it on the downloads page.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 6:52am
It's in the "PCB Library Construction Guidelines" section in the Forum -
IPC-7351 Pad Stack Naming Convention
Along with other library construction documents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 7:01am
Also on the "Downloads" page, look for the "Surface Mount Components" button.
Date updated (as of this point) is 8/15/2016.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 8:12am
Cheers Tom, is it not available as a PDF anywhere?
Nick, its not in the surface mount document - that's component naming - not padstack naming.
I really do need to gather all these docs and make a folder full - trying to find PDF's all the time is very time consuming. To hell with the idea of a paperless office - I cant doodle on that :)
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 2:22pm
PDF version is now available at http://www.PCBLibraries.com/Downloads
