  New Posts New Posts RSS Feed - How to Turn Off AutoUpdate.exe
wchappell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wchappell Quote  Post ReplyReply Direct Link To This Post Topic: How to Turn Off AutoUpdate.exe
    Posted: 27 Jul 2016 at 4:38am
How do I turn off or keep from loading the AutoUpdate.exe.
I don't have a problem with the LE Pro checking for updates when I start the program.
I do have a problem with having a back ground program that starts every time I turn on my computer.
I understand that some people like the the idea.
I would like option to turn it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 6:15am
Update to V2016.09. There is a new "Check for Update" in Help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wchappell Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 6:36am
I was not clear in what I was asking.
How do I stop the program/process X_FPX2016PRO_AutoUpdate.exe from loading at start up.
I have gone into the Check for Update and set it to Never
I then rebooted my computer.
The executable still loads on start up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 7:04am
Simply delete the EXE file. The Library Expert will work fine without it there. We're testing a much simpler "Check for Updates" function, and will soon discontinue using the Autoupdate EXE file.
mahmoodv99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 8:37pm
Remove PCB Library Expert Pro - Auto Update from start>starup
This page was generated in 0.420 seconds.
