  New Posts New Posts RSS Feed - Extended Footprint Names
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Extended Footprint Names
    Posted: 18 Jul 2016 at 1:15pm
What happened to the use extended footprint names and the include height in footprint name options?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 1:19pm
In Preferences you can choose to use either the IPC-7351B or C Land Pattern Naming Convention. It's in the Console > Design tab
If you use "C" you can regenerate all your footprint names in your FPX file in the Library Editor > Tools > Regenerate Library > Names
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:22pm
So is "C" the same as the previous extended names ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:25pm
Yes, the Extended Names were approved by the IPC Land Pattern Committee for IPC-7351C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:29pm
I just tried "C" it generated different names than the extended names we previously generated. Now we wind up with yet another set of different footprint names. Any way to go back to the previous naming convention ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:36pm
The Extended Names were adopted by IPC Land Pattern committee, but they also wanted to relocate the Pin Qty to the beginning of the land pattern name.
We no longer support "Extended Names" as they were just a place holder until the IPC committee finalized and approved a new naming convention.
You can go back to IPC-7351B, but that does not have Extended Names.
Or you can edit the Footprint Name to whatever name you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 3:40pm
Would it be possible to add a program flag so when you load a footprint from the existing library it keeps the same footprint name from the library. At least this way we can update existing footprints without changing the name.
This page was generated in 0.563 seconds.
