  New Posts New Posts RSS Feed - OrCAD 17.2 Pads Without Pastemask Generate Warning
Kyle G View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kyle G Quote  Post ReplyReply Direct Link To This Post Topic: OrCAD 17.2 Pads Without Pastemask Generate Warning
    Posted: 29 Jun 2016 at 5:07pm
The new padstack editor included with OrCad / Allegro 17.2 chokes on pads with a pastemask of dimension 0.  It throws a warning and refuses to generate the pad.  Instead of generating a pad with 0 dimension, the script should not generate any pad at all.
Here's a script which shows the failure:
# Allegro script
# Generated by FPX Expert
#   name:       c1800p0
QtSignal MainWindow New triggered
QtSignal fileNewDialog dataCombo CurrentIndexChanged "SMD Pin"
QtSignal fileNewDialog dataCombo activated "SMD Pin"
QtSignal fileNewDialog browse clicked
QtFillin c1800p0.pad
QtSignal fileNewDialog OK clicked
QtSignal MainWindow Units CurrentIndexChanged Millimeter
QtFillin Yes
QtSignal GuidedDesignLayersTab LayersTable cellClicked 0 "Regular Pad" None 0 2
QtSignal GuidedDesignLayersTab PadShape CurrentIndexChanged Circle
QtSignal GuidedDesignLayersTab PadShape activated Circle
QtSignal GuidedDesignLayersTab PadDiameter editingFinished 18
QtSignal GuidedMaskLayersTab LayersTable cellClicked 0 Pad None 0 1
QtSignal GuidedMaskLayersTab PadShape CurrentIndexChanged Circle
QtSignal GuidedMaskLayersTab PadShape activated Circle
QtSignal GuidedMaskLayersTab PadDiameter editingFinished 18
QtSignal GuidedMaskLayersTab LayersTable cellClicked 2 Pad None 2 1
QtSignal GuidedMaskLayersTab PadDiameter editingFinished 0
QtSignal MainWindow Save triggered
QtSignal MainWindow Exit triggered
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 10:53am
Instead of turning the FP Designer pad stack value to zero (0), why don't you remove (delete) the Paste Mask pad stack from the list?
This page was generated in 0.316 seconds.
