  New Posts New Posts RSS Feed - PADS vx 1.2 iCDB Dx Designer Flow
dsparks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dsparks Quote  Post ReplyReply Direct Link To This Post Topic: PADS vx 1.2 iCDB Dx Designer Flow
    Posted: 10 Jun 2016 at 12:07pm
Can someone explain how to get the Library Expert PADS Output files to import into PADS Standard Plus vx1.2 using the Dx Designer Integrated Flow with a Central Library?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2016 at 4:42pm
As far as I know there is no current way to get the part into the PADS Integrated Flow from PADS Layout and Mentor is aware of the problems surrounding this issue.
Currently you import our files into PADS Layout VX 1.2.
This page was generated in 0.969 seconds.
