Axial Vertical Mount |
mahmoodv99
Topic: Axial Vertical MountPosted: 31 May 2016 at 11:03pm |
How create Axial Component footprint with Vertical mount option ?
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6091 |
Posted: 01 Jun 2016 at 5:57am |
We use FP Designer to create both Vertical Mount Resistors and Lay Down Radial Lead capacitors.
mahmoodv99
Posted: 01 Jun 2016 at 7:56pm |
How Calculate pitch and height ?
No option in axial lead form calculator for vertical mount. It is available in LP calculator.. why not add in automatic library creation ?
Posted: 02 Jun 2016 at 7:29am |
These are the top 10 Library Expert develop items right now · Preferences: o Added SMD Proportional Pad Stack mathematical model for land pattern calculation · FP Designer: o Added irregular pad shape o Added irregular package body shape · Calculator: o Axial Lead component family – added auto-calculation of lead pitch o Added lay down Radial Lead component families o Added Standup Axial Lead component families · 3D STEP: o Added lay down Radial Lead component families o Added Standup Axial Lead component families |
mahmoodv99
Posted: 02 Jun 2016 at 8:43pm |
Its OK, but where is the option to calculate axial vertical mount pitch and height ?
Posted: 02 Jun 2016 at 8:58pm |
The height is the axial lead body length plus the lead bend radius. That is suggesting that you're going to mount the body flush with the PCB surface. |
mahmoodv99
Posted: 02 Jun 2016 at 9:09pm |
How calculate bend radius and pitch ?
Posted: 03 Jun 2016 at 1:41pm |
The pin pitch is 50% of the axial lead body round up to the nearest 1 mm or 0.1" grid (depending on if you design in millimeters or mil units. The total Height is the body plus the lead bend. Get a axial lead part and bend the lead how you want it and measure it. The Pin Pitch: Here is a screenshot from FP Designer and the grid display is 1 mm so the pin pitch = 3 mm ![]() |
