  New Posts New Posts RSS Feed - Drafting Settings
Drafting Settings
christian.fischerauer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote christian.fischerauer Quote  Post ReplyReply Direct Link To This Post Topic: Drafting Settings
    Posted: 20 May 2016 at 1:30am
PCB Library Expert Pro V2016.04 -
When changing a parameter in the tab 'Component -> Dimensions' after changing a parameter in the tab 'Drafting', the changed parameter in the tab 'Drafting' gets lost and the value specified in 'Preferences' is applied.
This was tested on multiple values in the 'Drafting' tab.
Regards,
Christian
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 7:27am
That's the way Library Expert Lite works.
You enter all component dimensions first.
Then you change local "Preferences" if you need to.
Then, if you change any component dimension, the program thinks you're creating a new part so it resets all "Preferences" back to default values.
However, with Library Expert Pro you setup all your Preferences and you can change any component dimension and your Preferences do not change, the Preferences are automatically applied to the new component dimensions.
This page was generated in 0.168 seconds.
