  New Posts New Posts RSS Feed - Custom Output For Allegro
mahmoodv99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Topic: Custom Output For Allegro
    Posted: 10 May 2016 at 10:29pm
Add option to include/exclude unwanted layers  from output file such as -
  1. DFA BOUND TOP
  2. DEV TYPE
  3. ASSEMBLY BOTTOM
  4. etc.
Post Options Post Options   Thanks (1) Thanks(1)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2016 at 9:35am
Hmm.. i'll consider it. How critical is this feature and what is the typical usage of when it is needed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2016 at 8:43pm
We are not using DEV TYPE and DFA BOUND TOP. So if you add option to exclude this, we can reduce our QA procedure for footprint verification.
GrungyRemnant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 7:12am
You should consider using SKILL to do any customization that you would like.
We don't run the scripts generated by the wizard directly.  They are all run though a SKILL routine where we customize the features to suit our needs.  For example making the Place_Bound_Top match the physical size of the component, create a DFA_BOUND_TOP shape to be more useful when using the DFA Constraints, or automatically assigning the DFA_DEV_CLASS to company approved values base on the footprint name/size.  The options are endless.
I think its the best way to handle this for any company's unique requirements.
Regards,
Chris
This page was generated in 3.125 seconds.
