  New Posts New Posts RSS Feed - TO-251AA I-PAK
TO-251AA I-PAK
lsday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsday Quote  Post ReplyReply Direct Link To This Post Topic: TO-251AA I-PAK
    Posted: 09 May 2016 at 11:34am
I have to build a cell for this package. It is a through hole with a thermal pad. What do I do with the thermal pad? I don't need to create a pad for it, correct? This is the part number IRLU2905ZPBF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 11:55am
Use the Through-hole "Flange Mount" Vertical or Horizontal calculators.
The Thermal Pad is a Plated though-hole for a mounting screw that should have a direct connection to the plane. i.e.: No Thermal Relief.
